Ir para o conteúdo principal
Dell XPS 15 9560 Touchpad Replacement
O que você precisa
  1. Dell XPS 15 9560 Touchpad Replacement, Back Panel: passo 1, imagem 1 %32
    • Using a T5 Torx screwdriver, remove ten 4.0 mm screws from the back panel of the laptop.
  2. Dell XPS 15 9560 Touchpad Replacement: passo 2, imagem 1 %32
    • Using a Phillips #2 screwdriver, remove two 5.0 mm screws underneath the XPS badge door.
  3. Dell XPS 15 9560 Touchpad Replacement: passo 3, imagem 1 %32
    • Wedge the scribe between the backplate and remove the bottom base cover.
  4. Dell XPS 15 9560 Touchpad Replacement, Battery: passo 4, imagem 1 %32
    • Using a T5 Torx screwdriver, remove the six 4.0 mm screws.
  5. Dell XPS 15 9560 Touchpad Replacement: passo 5, imagem 1 %32
    • Unplug the battery cable.
  6. Dell XPS 15 9560 Touchpad Replacement: passo 6, imagem 1 %32
    • Remove the battery.
  7. Dell XPS 15 9560 Touchpad Replacement, Hard Drive: passo 7, imagem 1 %32
    • Using a Phillips #0 screwdriver, remove four 4.0 mm screws of the hard drive bracket.
    • Unplug the hard drive cable.
  8. Dell XPS 15 9560 Touchpad Replacement: passo 8, imagem 1 %32
    • Remove the hard drive bracket. Then, unplug and remove the hard drive.
  9. Dell XPS 15 9560 Touchpad Replacement, Trackpad: passo 9, imagem 1 %32
    • Shutdown & unplug your laptop.
  10. Dell XPS 15 9560 Touchpad Replacement: passo 10, imagem 1 %32
    • Remove the two 5 mm mounting screws for the touchpad.
  11. Dell XPS 15 9560 Touchpad Replacement: passo 11, imagem 1 %32
    • Remove the 5mm screw to allow removal of the plate.
  12. Dell XPS 15 9560 Touchpad Replacement: passo 12, imagem 1 %32
    • Unplug the small cord from its slot on the board.
  13. Dell XPS 15 9560 Touchpad Replacement: passo 13, imagem 1 %32 Dell XPS 15 9560 Touchpad Replacement: passo 13, imagem 2 %32
    • Unplug the black cord from the board.
    • Unplug the cord with a white plug from the board.
  14. Dell XPS 15 9560 Touchpad Replacement: passo 14, imagem 1 %32 Dell XPS 15 9560 Touchpad Replacement: passo 14, imagem 2 %32
    • Gently pull the white ribbon cables loose from their housings.
  15. Dell XPS 15 9560 Touchpad Replacement: passo 15, imagem 1 %32
    • Lift the laptop so it's in the open position as shown.
    • Push the touchpad free from the keyboard side of the laptop.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 8
Últimos 7 dias: 30
Últimos 30 dias: 167
Duração total: 3,539
