Ir para o conteúdo principal
Dell XPS 15 9560 Motherboard Replacement
O que você precisa
  1. Dell XPS 15 9560 Motherboard Replacement, Back Panel: passo 1, imagem 1 %32
    • Using a T5 Torx screwdriver, remove ten 4.0 mm screws from the back panel of the laptop.
  2. Dell XPS 15 9560 Motherboard Replacement: passo 2, imagem 1 %32
    • Using a Phillips #2 screwdriver, remove two 5.0 mm screws underneath the XPS badge door.
  3. Dell XPS 15 9560 Motherboard Replacement: passo 3, imagem 1 %32
    • Wedge the scribe between the backplate and remove the bottom base cover.
  4. Dell XPS 15 9560 Motherboard Replacement, Battery: passo 4, imagem 1 %32
    • Using a T5 Torx screwdriver, remove the six 4.0 mm screws.
  5. Dell XPS 15 9560 Motherboard Replacement: passo 5, imagem 1 %32
    • Unplug the battery cable.
  6. Dell XPS 15 9560 Motherboard Replacement: passo 6, imagem 1 %32
    • Remove the battery.
  7. Dell XPS 15 9560 Motherboard Replacement, Hard Drive: passo 7, imagem 1 %32
    • Using a Phillips #0 screwdriver, remove four 4.0 mm screws of the hard drive bracket.
    • Unplug the hard drive cable.
  8. Dell XPS 15 9560 Motherboard Replacement: passo 8, imagem 1 %32
    • Remove the hard drive bracket. Then, unplug and remove the hard drive.
  9. Dell XPS 15 9560 Motherboard Replacement, Solid State Drive (SSD): passo 9, imagem 1 %32
    • Using a Phillips #2 screwdriver, remove a single 3.0 mm screw from the SSD bracket.
  10. Dell XPS 15 9560 Motherboard Replacement: passo 10, imagem 1 %32
    • Using the same Phillips #2 screwdriver, unscrew and remove one 2.0 mm wafer screw from the SSD bracket.
  11. Dell XPS 15 9560 Motherboard Replacement: passo 11, imagem 1 %32
    • Pull out and separate the SSD bracket and SSD, replacing the old SSD with a new one.
  12. Dell XPS 15 9560 Motherboard Replacement, Wireless Card: passo 12, imagem 1 %32
    • Using the Phillips #2 screwdriver, remove the single 4.0 mm screw securing the wireless card base to the motherboard.
  13. Dell XPS 15 9560 Motherboard Replacement: passo 13, imagem 1 %32
    • Disconnect the wireless card cables from the wireless card.
  14. Dell XPS 15 9560 Motherboard Replacement: passo 14, imagem 1 %32
    • Slide the wireless card out of its slot.
  15. Dell XPS 15 9560 Motherboard Replacement, Fans: passo 15, imagem 1 %32
    • Using a T5 Torx screwdriver, remove two 4.0 mm screws.
  16. Dell XPS 15 9560 Motherboard Replacement: passo 16, imagem 1 %32
    • Unplug the fan cable.
  17. Dell XPS 15 9560 Motherboard Replacement: passo 17, imagem 1 %32
    • Carefully remove the left-side fan.
  18. Dell XPS 15 9560 Motherboard Replacement: passo 18, imagem 1 %32
  19. Dell XPS 15 9560 Motherboard Replacement: passo 19, imagem 1 %32
    • Remove the right-side fan.
  20. Dell XPS 15 9560 Motherboard Replacement, RAM: passo 20, imagem 1 %32 Dell XPS 15 9560 Motherboard Replacement, RAM: passo 20, imagem 2 %32
    • Pull the metal clips surrounding the RAM stick outward.
    • The RAM will pop out.
    • Remove the RAM stick from the device.
  21. Dell XPS 15 9560 Motherboard Replacement, Motherboard: passo 21, imagem 1 %32
    • Using a screwdriver, unscrew one 5.0 mm Torx T5 bracket screw.
    • Remove the bracket and unplug and loosen the LCD cable.
  22. Dell XPS 15 9560 Motherboard Replacement: passo 22, imagem 1 %32
    • Using a T5 Torx screwdriver, remove ten 4.0 mm screws securing the motherboard to the device.
  23. Dell XPS 15 9560 Motherboard Replacement: passo 23, imagem 1 %32
    • From right to left, unplug the bottom motherboard cables, DC jack cable, speaker cable.
  24. Dell XPS 15 9560 Motherboard Replacement: passo 24, imagem 1 %32
    • Remove the motherboard.
Conclusão
Jada Houser
Membro desde: 09/28/21
790 Reputação
Autoria de 7 guias
Equipe
Clemson, Team 4-5, Hunter Fall 2021 Membro de Clemson, Team 4-5, Hunter Fall 2021
CLEM-HUNTER-F21S4G5
Membros da 4
Autoria de 15 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 30
Últimos 30 dias: 96
Duração total: 3,714
