Pular para o conteúdo principal
Introdução
If the laptop will not connect to wireless internet, you may need a new wireless card.
Peças
Nenhum componente especificado.
  1. Turn the laptop upside down.
    • Turn the laptop upside down.
    • Make sure the laptop is turned off.
    • Using the T5 Torx Screwdriver, remove the ten 3 mm long screws from the perimeter of the back of the laptop.
  2. Open up the information panel door (on the middle of the back side). While holding the door open, use the Phillips #00 Screwdriver to remove the two 10 mm long screws.
    • Open up the information panel door (on the middle of the back side).
    • While holding the door open, use the Phillips #00 Screwdriver to remove the two 10 mm long screws.
  3. PC Laptop Batteries
    An easy fix for a big power boost.
    Comprar agora
    PC Laptop Batteries
    Comprar agora
  4. Carefully lift 2  corners of the back panel upwards, releasing the whole panel. Do not force the panel off. If it does not come off easily, try using a plastic spudger where it is stuck. Do not force the panel off. If it does not come off easily, try using a plastic spudger where it is stuck.
    • Carefully lift 2 corners of the back panel upwards, releasing the whole panel.
    • Do not force the panel off. If it does not come off easily, try using a plastic spudger where it is stuck.
  5. With a Philips #00 Screwdriver bit, remove one 4 mm long black screw located by the antenna connections on the wireless card.
    • With a Philips #00 Screwdriver bit, remove one 4 mm long black screw located by the antenna connections on the wireless card.
    • Set the screw and metal holder aside.
  6. Gently lift up each of the antennas (3) to disconnect them from the wireless card. These are similar to a coat button, the antennas snap on and snap off.
    • Gently lift up each of the antennas (3) to disconnect them from the wireless card.
    • These are similar to a coat button, the antennas snap on and snap off.
  7. With the antennas disconnected, gently pull the wireless card out at the angle it sits at. The wireless card has been successfully removed! The wireless card has been successfully removed!
    • With the antennas disconnected, gently pull the wireless card out at the angle it sits at.
    • The wireless card has been successfully removed!
Conclusão
Uma outra pessoa concluiu este guia.
Hunter J Laska
Membro desde: 04-10-2018
112 reputação
Autoria de 1 guia
Equipe
UW Stout, Team S6-G1, Ogden Fall 2018 Membro de UW Stout, Team S6-G1, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G1
4 Membros
5 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 81
Últimos 30 dias: 227
Todo: 1,460
