Ir para o conteúdo principal
Dell XPS 15 9550 Solid State Drive Replacement
O que você precisa
  1. Dell XPS 15 9550 Solid State Drive Replacement, Back/Underside Panel: passo 1, imagem 1 %32
    • Turn the laptop upside down.
    • Make sure the laptop is turned off.
    • Use a T5 Torx Screwdriver to remove the ten 3 mm long screws from the perimeter of the back of the laptop.
  2. Dell XPS 15 9550 Solid State Drive Replacement: passo 2, imagem 1 %32 Dell XPS 15 9550 Solid State Drive Replacement: passo 2, imagem 2 %32
    • Open up the information panel door (on the middle of the back side).
    • While holding the door open, use a Phillips #00 Screwdriver to remove the two 10 mm long screws.
  3. Dell XPS 15 9550 Solid State Drive Replacement: passo 3, imagem 1 %32 Dell XPS 15 9550 Solid State Drive Replacement: passo 3, imagem 2 %32 Dell XPS 15 9550 Solid State Drive Replacement: passo 3, imagem 3 %32
    • Carefully lift the 2 corners of the back panel close to the hinge upwards, to release the whole panel.
    • Do not force the panel off. If it does not come off easily, try to use a plastic spudger where it is stuck.
  4. Dell XPS 15 9550 Solid State Drive Replacement, Solid State Drive: passo 4, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove the SSD screw.
  5. Dell XPS 15 9550 Solid State Drive Replacement: passo 5, imagem 1 %32 Dell XPS 15 9550 Solid State Drive Replacement: passo 5, imagem 2 %32
    • Gently remove the SSD.
Conclusão
Uma outra pessoa concluiu este guia.
Zach Jones
Membro desde: 03/25/22
400 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team 2-4, Harley Spring 2022 Membro de IUPUI, Team 2-4, Harley Spring 2022
IUPUI-HARLEY-S22S2G4
3 Membros
Autoria de 3 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 16
Últimos 30 dias: 41
Ao todo: 2,418
