Ir para o conteúdo principal
Dell XPS 15 9550 Cooling Fan(s) Replacement
O que você precisa
  1. Dell XPS 15 9550 Cooling Fan(s) Replacement, Back/Underside Panel: passo 1, imagem 1 %32
    • Turn the laptop upside down.
    • Make sure the laptop is turned off.
    • Use a T5 Torx Screwdriver to remove the ten 3 mm long screws from the perimeter of the back of the laptop.
  2. Dell XPS 15 9550 Cooling Fan(s) Replacement: passo 2, imagem 1 %32 Dell XPS 15 9550 Cooling Fan(s) Replacement: passo 2, imagem 2 %32
    • Open up the information panel door (on the middle of the back side).
    • While holding the door open, use a Phillips #00 Screwdriver to remove the two 10 mm long screws.
  3. Dell XPS 15 9550 Cooling Fan(s) Replacement: passo 3, imagem 1 %32 Dell XPS 15 9550 Cooling Fan(s) Replacement: passo 3, imagem 2 %32 Dell XPS 15 9550 Cooling Fan(s) Replacement: passo 3, imagem 3 %32
    • Carefully lift the 2 corners of the back panel close to the hinge upwards, to release the whole panel.
    • Do not force the panel off. If it does not come off easily, try to use a plastic spudger where it is stuck.
  4. Dell XPS 15 9550 Cooling Fan(s) Replacement, Cooling Fan(s): passo 4, imagem 1 %32
    • Use the Small Plastic Spudger to carefully disconnect the white connector from the black port.
  5. Dell XPS 15 9550 Cooling Fan(s) Replacement: passo 5, imagem 1 %32 Dell XPS 15 9550 Cooling Fan(s) Replacement: passo 5, imagem 2 %32 Dell XPS 15 9550 Cooling Fan(s) Replacement: passo 5, imagem 3 %32
    • Use the Phillips #00 Screwdriver to remove the two 4 mm long screws.
    • The location of the 2 screws is different on each fan.
    • The left fan screw locations are circled in red.
    • The right fan screw locations are circled in orange.
  6. Dell XPS 15 9550 Cooling Fan(s) Replacement: passo 6, imagem 1 %32 Dell XPS 15 9550 Cooling Fan(s) Replacement: passo 6, imagem 2 %32
    • With the screws removed, lift up on the fan and remove it from the laptop.
Conclusão
8 outras pessoas executaram este guia.
Brandon Schmidt
Membro desde: 10/04/18
2.090 Reputação
Autoria de 3 guias
Equipe
UW Stout, Team S6-G1, Ogden Fall 2018 Membro de UW Stout, Team S6-G1, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G1
Membros da 4
Autoria de 23 guias
5 comentários
I removed the fans for cleaning the dust. Now the left fan is always at 100%. Can anybody help me with that problem? Is it possible to somehow misconnect the fan? Or did I accidently did something to the temperature sensors?
Hendrik Lippka - Responder
DId you manage to fix the problem? I have the same issue with the right fan.
James Reid -
I have the exact same issue on the “right” fan.
I wonder if it broke by blowing air through it
Albert Einstein -
Merci pour votre tuto fort bien construit. Pour toute intervention sur de l'électronique : être hors tension. 1/ débrancher secteur ET déconnecter la batterie. 2/ utilisez des matériels qui isolent de l'électricité statique (p.e., plaque a déployer sous le matériel). A défaut, éviter les pulls en laine polaire ou autres, les moquettes, les vêtements amples, les outils métalliques ... 3/ Ne pas toucher les composants électroniques : dévisser puis soulever avec une spatule en plastique puis saisir les circuits par les côtés. Les poser sur un endroit sûr hors de la machine. 4/ prenez des photos avant et après (sauvegardez et classez-les : plus pertinent que la prise de notes). 5/ Ne posez pas d'outil sur la machine, ranger les vis par type (les photos peuvent aider a retrouver les bonnes) 6/ changer RAM en paires identiques : capacité et caractéristiques. 7/ nettoyez votre PC 2 fois/an : un bon refroidissement améliore les perfs, la surchauffe est mortelle. Un clavier dépoussiéré dessus / dessous redevient neuf.
Tigris - Responder
En réponse aux précédents posts : je n'est rencontré aucun problème mais j'ai mis a jour le Bios et un autre utilitaire préconisés par Dell et tous les utilitaires demandés (8 je crois) par le service TAG.
Mon Dell XPS 15 7590 fonctionne a nouveau après avoir été bloqué par le BIOS suite a un encrassement dû aux poussières qui empêchaient le refroidissement : une sécurité du système plus qu'utile !
note 1 : le système m'a donné un QR code : mon smartphone a pu se connecter au service dépannage Dell avec 2 conseils malgré la fin de la garantie depuis 2 ans.
note 2 : mes ventilateurs vont un bruit irrégulier en position batterie malgré le dépoussiérage des ventilateurs démontés ainsi que la carte mère et le clavier.
Mais en usage nomade (batterie), les ventilateurs font un bruit intermittent.
PS : j'ai trouvé 2 rondelles sur mon bureau : sèches et cassées (environ 2.5cm de diamètre) j'ignore d'où elles viennent ? de mon XPS 15 ou pas ?
Est-ce cela qui fait que les ventilateurs sont parfois bruyants en usage batterie?
Tigris - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 15
Últimos 30 dias: 59
Duração total: 12,023
