Ir para o conteúdo principal
Introdução
Before the majority of components can be accessed to be replaced, the back panel will need to come off.
Peças
Nenhum componente especificado.
  1. Turn the laptop upside down.
    • Turn the laptop upside down.
    • Make sure the laptop is turned off.
    • Using a T5 Torx Screwdriver, remove the ten 3 mm long screws from the perimeter of the back of the laptop.
  2. Open up the information panel door (on the middle of the back side). While holding the door open, use a Phillips #00 Screwdriver to remove the two 10 mm long screws.
    • Open up the information panel door (on the middle of the back side).
    • While holding the door open, use a Phillips #00 Screwdriver to remove the two 10 mm long screws.
  3. Carefully lift the 2 corners of the back panel close to the hinge upwards, releasing the whole panel. Do not force the panel off. If it does not come off easily, try using a plastic spudger where it is stuck. Do not force the panel off. If it does not come off easily, try using a plastic spudger where it is stuck.
    • Carefully lift the 2 corners of the back panel close to the hinge upwards, releasing the whole panel.
    • Do not force the panel off. If it does not come off easily, try using a plastic spudger where it is stuck.
Conclusão
9 outras pessoas concluíram este guia.
Brandon Schmidt
Membro desde: 04/10/2018
1.432 Reputação
3 Guias de autoria
Equipe
UW Stout, Team S6-G1, Ogden Fall 2018 Membro de UW Stout, Team S6-G1, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G1
4 Membros
21 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 25
Últimos 30 dias: 122
Duração total: 7,482
