Ir para o conteúdo principal
Dell XPS 15 9530 WiFi Card Replacement
O que você precisa
  1. Dell XPS 15 9530 WiFi Card Replacement, Base Cover: passo 1, imagem 1 %32 Dell XPS 15 9530 WiFi Card Replacement, Base Cover: passo 1, imagem 2 %32 Dell XPS 15 9530 WiFi Card Replacement, Base Cover: passo 1, imagem 3 %32
    • Using a T5 Torx screwdriver, remove ten 3mm screws.
  2. Dell XPS 15 9530 WiFi Card Replacement: passo 2, imagem 1 %32 Dell XPS 15 9530 WiFi Card Replacement: passo 2, imagem 2 %32
    • Lift the plastic tab.
    • Remove two 3mm Phillips #0 screws under the plastic tab.
  3. Dell XPS 15 9530 WiFi Card Replacement: passo 3, imagem 1 %32
    • Lift the lower case off.
  4. Dell XPS 15 9530 WiFi Card Replacement, WiFi Card: passo 4, imagem 1 %32
    • Use a Phillips #0 screwdriver to remove the screw holding the WiFi card down. Be careful not to lose the metal retainer holding the antenna cables down.
    • Without applying too much force, pop out the antenna cables and remove the card.
    • Insert the new card, and reattach the antenna cables. The black cable connects to the main antenna slot (marked with a solid triangle) and the white connects to the auxiliary (marked with an empty triangle).
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 17
Últimos 30 dias: 47
Duração total: 1,748
