Introdução
Removal of the screen will be covered in this guide. To successfully remove the battery, a #0 Phillips screwdriver, a T5 Torx screwdriver, tweezers, and a plastic spudger are needed. Be careful disconnecting cables as to not break them or their connectors.
O que você precisa
Using a Phillips #0 screwdriver, remove the seven 3.5mm screws that secure the battery to the palm rest assembly.
Pull lift tabs and remove the plastic that covers the hard drive to expose the hard drive.
Uma outra pessoa concluiu este guia.
