Ir para o conteúdo principal
Dell XPS 15 9530 Screen Replacement
O que você precisa
  1. Dell XPS 15 9530 Screen Replacement, Base Cover: passo 1, imagem 1 %32 Dell XPS 15 9530 Screen Replacement, Base Cover: passo 1, imagem 2 %32 Dell XPS 15 9530 Screen Replacement, Base Cover: passo 1, imagem 3 %32
    • Using a T5 Torx screwdriver, remove ten 3mm screws.
  2. Dell XPS 15 9530 Screen Replacement: passo 2, imagem 1 %32 Dell XPS 15 9530 Screen Replacement: passo 2, imagem 2 %32
    • Lift the plastic tab.
    • Remove two 3mm Phillips #0 screws under the plastic tab.
  3. Dell XPS 15 9530 Screen Replacement: passo 3, imagem 1 %32
    • Lift the lower case off.
  4. Dell XPS 15 9530 Screen Replacement, Battery: passo 4, imagem 1 %32 Dell XPS 15 9530 Screen Replacement, Battery: passo 4, imagem 2 %32
    • Using a Phillips #0 screwdriver, remove the seven 3.5mm screws that secure the battery to the palm rest assembly.
  5. Dell XPS 15 9530 Screen Replacement: passo 5, imagem 1 %32
    • Disconnect the battery cable from the system board.
    • Be sure to use a plastic tool, not a metal one.
  6. Dell XPS 15 9530 Screen Replacement: passo 6, imagem 1 %32
    • Lift the battery off the chassis.
  7. Dell XPS 15 9530 Screen Replacement, SSD: passo 7, imagem 1 %32
    • Pull lift tabs and remove the plastic that covers the hard drive to expose the hard drive.
  8. Dell XPS 15 9530 Screen Replacement: passo 8, imagem 1 %32 Dell XPS 15 9530 Screen Replacement: passo 8, imagem 2 %32
    • Using a Phillips #0 screwdriver, remove two 2.5mm screws that secure the SSD to the chassis.
  9. Dell XPS 15 9530 Screen Replacement: passo 9, imagem 1 %32
    • Pull the SSD out parallel to the mainboard.
  10. Dell XPS 15 9530 Screen Replacement, Screen: passo 10, imagem 1 %32 Dell XPS 15 9530 Screen Replacement, Screen: passo 10, imagem 2 %32
    • Unplug the screen connector.
  11. Dell XPS 15 9530 Screen Replacement: passo 11, imagem 1 %32 Dell XPS 15 9530 Screen Replacement: passo 11, imagem 2 %32
    • Using a Phillips #0 screwdriver, remove the four 4mm screws holding in the screen hinges.
  12. Dell XPS 15 9530 Screen Replacement: passo 12, imagem 1 %32
    • Pull chassis away from screen assembly.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 16
Últimos 30 dias: 42
Duração total: 1,437
