Introdução
Removal of the keyboard will be covered in this guide. To successfully remove the keyboard, a #0 Phillips screwdriver, a T5 Torx screwdriver, a plastic spudger, and tweezers are needed. Be careful disconnecting cables as to not break them or their connectors.
O que você precisa
Using a Phillips #0 screwdriver, remove the seven 3.5mm screws that secure the battery to the palm rest assembly.
Um comentário
Thank you for this guide! Is there any way to obtain replacement screws for the outer perimeter of the keyboard? I’ve recently disassembled my XPS 9530 and found one of the screws is very stripped, I managed to get it out but it really shouldn’t be put back in due to the state of the head.
I’m struggling to find replacements for the size quoted. Are they Phillips M2 3mm silver screws?
