Introdução
How to replace the battery of a Dell XPS 15 9530.
O que você precisa
Passo 1 Unscrewing the Base-Cover Assembly
Cuidado: as etapas de 1 a 2 são provenientes de um guia marcado como em andamento.
After turning off the system, unscrew the 12 Philips screws (#1) that are on the bottom of the laptop.
Using a spudger or some other prying tool (#1), pry off the base-cover assembly from the rest of the system.
Remove the screws that secure the battery to the palm-rest assembly.
Disconnect the battery cable from the system board.
Lift the battery off the palm-rest assembly.
5 outras pessoas executaram este guia.
