Ir para o conteúdo principal
Dell XPS 15 9510 SSD Replacement
O que você precisa
  1. Dell XPS 15 9510 SSD Replacement, Lower Case: passo 1, imagem 1 %32
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
  2. Dell XPS 15 9510 SSD Replacement: passo 2, imagem 1 %32
    • The metal case of the XPS 15 9510 is extremely sharp, so be careful not to run your fingers along the edge when disassembling the laptop.
    • Wedge the case apart with a nylon spudger.
    • If the plastic one isn't possible to insert, use the metal spudger to carefully create a small gap first.
    • Slide spudger along each side of the laptop
  3. Dell XPS 15 9510 SSD Replacement: passo 3, imagem 1 %32
    • Lift the back panel of the laptop off and set it aside.
  4. Dell XPS 15 9510 SSD Replacement, SSD: passo 4, imagem 1 %32 Dell XPS 15 9510 SSD Replacement, SSD: passo 4, imagem 2 %32
    • Remove the single screw from the left side of the SSD using a Phillips #00 screwdriver.
    • The SSD is spring-released; it will pop up after removing the screw.
  5. Dell XPS 15 9510 SSD Replacement: passo 5, imagem 1 %32
    • Use your fingers to carefully remove the SSD from the laptop.
Conclusão
3 outras pessoas executaram este guia.
Austin Sa
Membro desde: 03/30/22
432 Reputação
Autoria de 3 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 56
Ao todo: 4,877
