Ir para o conteúdo principal
Dell XPS 15 9510 Lower Case Replacement
O que você precisa
  1. Dell XPS 15 9510 Lower Case Replacement, Lower Case: passo 1, imagem 1 %32
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
  2. Dell XPS 15 9510 Lower Case Replacement: passo 2, imagem 1 %32
    • The metal case of the XPS 15 9510 is extremely sharp, so be careful not to run your fingers along the edge when disassembling the laptop.
    • Wedge the case apart with a nylon spudger.
    • If the plastic one isn't possible to insert, use the metal spudger to carefully create a small gap first.
    • Slide spudger along each side of the laptop
  3. Dell XPS 15 9510 Lower Case Replacement: passo 3, imagem 1 %32
    • Lift the back panel of the laptop off and set it aside.
Conclusão
Joseph Remondi
Membro desde: 03/30/22
290 Reputação
Autoria de 2 guias
Equipe
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 17
Últimos 30 dias: 48
Ao todo: 1,429
