Ir para o conteúdo principal
Dell XPS 15 9510 Display Assembly Replacement
O que você precisa
  1. Dell XPS 15 9510 Display Assembly Replacement, Rear Panel: passo 1, imagem 1 %32
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
  2. Dell XPS 15 9510 Display Assembly Replacement: passo 2, imagem 1 %32
    • The metal case of the XPS 15 9510 is extremely sharp, so be careful not to run your fingers along the edge when disassembling the laptop.
    • Wedge the case apart with a nylon spudger.
    • If the plastic one isn't possible to insert, use the metal spudger to carefully create a small gap first.
    • Slide spudger along each side of the laptop
  3. Dell XPS 15 9510 Display Assembly Replacement: passo 3, imagem 1 %32
    • Lift the back panel of the laptop off and set it aside.
  4. Dell XPS 15 9510 Display Assembly Replacement, Display Assembly: passo 4, imagem 1 %32
    • Remove the four screws (eight total) from each display hinge using a Phillips #00 screwdriver.
  5. Dell XPS 15 9510 Display Assembly Replacement: passo 5, imagem 1 %32
    • Remove five screws that connect the display using a Phillips #00 screwdriver.
  6. Dell XPS 15 9510 Display Assembly Replacement: passo 6, imagem 1 %32
    • Carefully remove the display from the Dell XPS 15 9510.
Conclusão
Austin Sa
Membro desde: 03/30/22
432 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 1-3, Mellen Spring 2022 Membro de UMass Dartmouth, Team 1-3, Mellen Spring 2022
UMASSD-MELLEN-S22S1G3
Membros da 3
Autoria de 5 guias
2 comentários
Missing a very important step.
Two small screws above the display cable clamp - Step 5 - need to be removed. If you look at the picture in step 5, the far left red/orange circle actually contains one. You can spot it inside and at the top of the of the circle. You can't separate the display assembly without removing those 2 screws.
Joshua Kleier - Responder
Aren't there any cables that need to be removed?
Ned Eff - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 21
Últimos 30 dias: 101
Duração total: 3,091
