Ir para o conteúdo principal
Dell XPS 15 9510 Battery Replacement
O que você precisa
  1. Dell XPS 15 9510 Battery Replacement, Lower Case: passo 1, imagem 1 %32
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
  2. Dell XPS 15 9510 Battery Replacement: passo 2, imagem 1 %32
    • The metal case of the XPS 15 9510 is extremely sharp, so be careful not to run your fingers along the edge when disassembling the laptop.
    • Wedge the case apart with a nylon spudger.
    • If the plastic one isn't possible to insert, use the metal spudger to carefully create a small gap first.
    • Slide spudger along each side of the laptop
  3. Dell XPS 15 9510 Battery Replacement: passo 3, imagem 1 %32
    • Lift the back panel of the laptop off and set it aside.
  4. Dell XPS 15 9510 Battery Replacement, Battery: passo 4, imagem 1 %32 Dell XPS 15 9510 Battery Replacement, Battery: passo 4, imagem 2 %32
    • Using the small battery pull tab, disconnect the battery connector from the motherboard.
  5. Dell XPS 15 9510 Battery Replacement: passo 5, imagem 1 %32
    • Remove eight 2.5 mm from around the perimeter of the battery using a Phillips #0 screwdriver.
  6. Dell XPS 15 9510 Battery Replacement: passo 6, imagem 1 %32 Dell XPS 15 9510 Battery Replacement: passo 6, imagem 2 %32
    • There are many delicate components in the vicinity of the battery, so be extremely careful removing it
    • Remove the old battery from the laptop.
Conclusão
5 outras pessoas executaram este guia.
Joseph Remondi
Membro desde: 03/30/22
290 Reputação
Autoria de 2 guias
Equipe
1Comentário do guia
XPS 15 9510 states the battery (purchased from ifixit) is FAKE and the battery will not charge.
Jacques Aucamp - Responder
Comentar
Visualizações:
Últimas 24 horas: 20
Últimos 7 dias: 99
Últimos 30 dias: 388
Ao todo: 6,846
