Ir para o conteúdo principal
Dell XPS 15 9500 Speaker Replacement
O que você precisa
  1. Dell XPS 15 9500 Speaker Replacement, Base Panel: passo 1, imagem 1 %32
    • Remove the eight 3.0 mm screws from the bottom panel with a T5 Torx screwdriver.
  2. Dell XPS 15 9500 Speaker Replacement: passo 2, imagem 1 %32 Dell XPS 15 9500 Speaker Replacement: passo 2, imagem 2 %32
    • Gently wedge an opening tool in the gap between the base panel and chassis, and pry vertically around the perimeter until it releases from the chassis.
    • Lift the base panel up and away from the chassis.
  3. Dell XPS 15 9500 Speaker Replacement, Speaker: passo 3, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove the two 3.0 mm screws (one on each speaker).
    • Use an opening tool to lift out the speaker.
  4. Dell XPS 15 9500 Speaker Replacement: passo 4, imagem 1 %32 Dell XPS 15 9500 Speaker Replacement: passo 4, imagem 2 %32
    • Use an opening tool to push the left speaker's cable out of its port until it is disconnected.
    • The speaker on the right side isn't connected to the motherboard, and is only connected to the left speaker by a wire at the bottom.
Conclusão
Bryan Chung
Membro desde: 10/18/19
437 Reputação
Autoria de 4 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 33
Duração total: 857
