Introdução
The RAM is as important to your device as the hard drive is. The RAM holds temporary data and it stores every piece of software information that you have to allow it to run smoothly. This helpful guide will show you how to take your RAM out and replace it with a new one. You will need a plastic opening tool and a Phillips #0 screwdriver.
O que você precisa
Remove the back cover of the laptop by unscrewing eight 3.5mm screws using a Phillips #0 screwdriver.
