Ir para o conteúdo principal
Dell XPS 14Z L412Z LCD Screen Glass Replacement
O que você precisa
  1. Dell XPS 14Z L412Z LCD Screen Glass Replacement, LCD Screen Glass: passo 1, imagem 1 %32 Dell XPS 14Z L412Z LCD Screen Glass Replacement, LCD Screen Glass: passo 1, imagem 2 %32
    • Using the iFixit opening tools, carefully pry up the trim around the screen.
    • It is recommended to start in a corner.
  2. Dell XPS 14Z L412Z LCD Screen Glass Replacement: passo 2, imagem 1 %32 Dell XPS 14Z L412Z LCD Screen Glass Replacement: passo 2, imagem 2 %32
    • Using a heat gun, carefully apply heat evenly across the glass.
  3. Dell XPS 14Z L412Z LCD Screen Glass Replacement: passo 3, imagem 1 %32 Dell XPS 14Z L412Z LCD Screen Glass Replacement: passo 3, imagem 2 %32
    • Using the iFixit opening tools, carefully pry the glass off the screen.
    • This is glass and will shatter if too much force is used.
Conclusão
Colton Niewolny
Membro desde: 02/15/18
411 Reputação
Autoria de 4 guias
Equipe
UW Stout, Team S8-G3, Ogden Spring 2018 Membro de UW Stout, Team S8-G3, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G3
Membros da 4
Autoria de 6 guias
Um comentário
to remove the black cover, use the rod of a pen pen cap. Spread both sides while pressing the top of the black cover (towards the inside of the screen). Must a little force.The closure mechanism is composed of two things that alternate every 2 cm: 1 clips that is sinking on the gray part (you have to lift the black part towards the right to take it out) then 1 rod that comes down in underneath (just stand aside - neither lift nor lower to remove)
wiwi - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Duração total: 2,113
