Pular para o conteúdo principal
Introdução
The glass layer is important to clarity and protection of the LCD screen. However, accidents can cause the screen to crack which harms the viewing experience. This replacement is extremely difficult and requires attentive care and knowing your way around the tools. The tools required are the plastic opening tool, heat gun, and a Phillips #0 screwdriver.
  1. Using the iFixit opening tools, carefully pry up the trim around the screen. It is recommended to start in a corner.
    • Using the iFixit opening tools, carefully pry up the trim around the screen.
    • It is recommended to start in a corner.
  2. Kit de Reparo de Bateria do MacBook
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  3. Using a heat gun, carefully apply heat evenly across the glass. Using a heat gun, carefully apply heat evenly across the glass.
    • Using a heat gun, carefully apply heat evenly across the glass.
  4. Using the iFixit opening tools, carefully pry the glass off the screen. This is glass and will shatter if too much force is used.
    • Using the iFixit opening tools, carefully pry the glass off the screen.
    • This is glass and will shatter if too much force is used.
Conclusão
Colton Niewolny
Membro desde: 15-02-2018
403 reputação
4 Guias de autoria
Equipe
UW Stout, Team S8-G3, Ogden Spring 2018 Membro de UW Stout, Team S8-G3, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G3
4 Membros
6 Guias de autoria
to remove the black cover, use the rod of a pen pen cap. Spread both sides while pressing the top of the black cover (towards the inside of the screen). Must a little force.The closure mechanism is composed of two things that alternate every 2 cm: 1 clips that is sinking on the gray part (you have to lift the black part towards the right to take it out) then 1 rod that comes down in underneath (just stand aside - neither lift nor lower to remove)
wiwi - Responder
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 33
Todo: 344
