Ir para o conteúdo principal
Dell XPS 14Z L412Z Hard Drive Replacement
O que você precisa
  1. Dell XPS 14Z L412Z Hard Drive Replacement, Back Panel: passo 1, imagem 1 %32
    • Remove the back cover of the laptop by unscrewing eight 3.5mm screws using a Phillips #0 screwdriver.
  2. Dell XPS 14Z L412Z Hard Drive Replacement: passo 2, imagem 1 %32 Dell XPS 14Z L412Z Hard Drive Replacement: passo 2, imagem 2 %32
    • Using the plastic opening tool, pry up the back cover.
    • It is recommended to start from a corner and run the tool along the edge of the cover.
  3. Dell XPS 14Z L412Z Hard Drive Replacement, Hard Drive: passo 3, imagem 1 %32 Dell XPS 14Z L412Z Hard Drive Replacement, Hard Drive: passo 3, imagem 2 %32
    • Locate the hard drive on the bottom right corner.
    • Unscrew the three 3.5mm screws with the Phillips #0 screwdriver.
  4. Dell XPS 14Z L412Z Hard Drive Replacement: passo 4, imagem 1 %32
    • Remove the four additional 3.5mm screws using the Phillips #0 screwdriver.
  5. Dell XPS 14Z L412Z Hard Drive Replacement: passo 5, imagem 1 %32
    • Carefully pull and remove the old hard drive.
Conclusão
Colton Niewolny
Membro desde: 02/15/18
411 Reputação
Autoria de 4 guias
Equipe
UW Stout, Team S8-G3, Ogden Spring 2018 Membro de UW Stout, Team S8-G3, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G3
Membros da 4
Autoria de 6 guias
Um comentário
On my laptop there was a small curved metal bracket that sat in the very corner of the PC covering one corner of the hard drive. That had to be removed by loosening a screw and gently prying the bar out before the hard drive could be removed.
dude - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Duração total: 1,537
