Ir para o conteúdo principal
Dell XPS 14Z L412Z Battery Replacement
O que você precisa
  1. Dell XPS 14Z L412Z Battery Replacement, Back Panel: passo 1, imagem 1 %32
    • Remove the back cover of the laptop by unscrewing eight 3.5mm screws using a Phillips #0 screwdriver.
  2. Dell XPS 14Z L412Z Battery Replacement: passo 2, imagem 1 %32 Dell XPS 14Z L412Z Battery Replacement: passo 2, imagem 2 %32
    • Using the plastic opening tool, pry up the back cover.
    • It is recommended to start from a corner and run the tool along the edge of the cover.
  3. Dell XPS 14Z L412Z Battery Replacement, Battery: passo 3, imagem 1 %32
    • The battery is on the bottom left side.
  4. Dell XPS 14Z L412Z Battery Replacement: passo 4, imagem 1 %32
    • Unscrew the five 4.5mm Phillips #0 screws around the battery.
  5. Dell XPS 14Z L412Z Battery Replacement: passo 5, imagem 1 %32 Dell XPS 14Z L412Z Battery Replacement: passo 5, imagem 2 %32
    • Using the plastic opening tools, carefully unplug the battery connection.
    • Then, plug your replacement battery into the new connection.
Conclusão
4 outras pessoas executaram este guia.
Colton Niewolny
Membro desde: 02/15/18
411 Reputação
Autoria de 4 guias
Equipe
UW Stout, Team S8-G3, Ogden Spring 2018 Membro de UW Stout, Team S8-G3, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G3
Membros da 4
Autoria de 6 guias
Um comentário
It worked smoothly! Less than 15 minutes. I used a OEM-battery, instead of an original one.
Jean Wallemacq - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 8
Duração total: 2,912
