Pular para o conteúdo principal
Introdução
The battery is the main power supply to the laptop. Keeping a healthy battery is good for your device's health. A worn out battery can cause overheating of the device and it will have a shorter battery life. The removal of the battery is fairly simple and this guide will show you how to remove it. You will need a plastic opening tool and a Phillips #0 screwdriver.
Peças
Nenhum componente especificado.
  1. Remove the back cover of the laptop by unscrewing eight 3.5mm screws using a Phillips #0 screwdriver.
    • Remove the back cover of the laptop by unscrewing eight 3.5mm screws using a Phillips #0 screwdriver.
  2. Using the plastic opening tool, pry up the back cover. It is recommended to start from a corner and run the tool along the edge of the cover.
    • Using the plastic opening tool, pry up the back cover.
    • It is recommended to start from a corner and run the tool along the edge of the cover.
  3. Kit de Reparo de Bateria do MacBook
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  4. The battery is on the bottom left side.
    • The battery is on the bottom left side.
  5. Unscrew the five 4.5mm Phillips #0 screws around the battery.
    • Unscrew the five 4.5mm Phillips #0 screws around the battery.
  6. Using the plastic opening tools, carefully unplug the battery connection. Then, plug your replacement battery into the new connection.
    • Using the plastic opening tools, carefully unplug the battery connection.
    • Then, plug your replacement battery into the new connection.
Conclusão
3 outras pessoas concluíram este guia.
Colton Niewolny
Membro desde: 15-02-2018
403 reputação
4 Guias de autoria
Equipe
UW Stout, Team S8-G3, Ogden Spring 2018 Membro de UW Stout, Team S8-G3, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G3
4 Membros
6 Guias de autoria
It worked smoothly! Less than 15 minutes. I used a OEM-battery, instead of an original one.
Jean Wallemacq - Responder
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 45
Todo: 597
