Ir para o conteúdo principal
Dell XPS 1340 CPU Fan Replacement
O que você precisa
  1. Dell XPS 1340 CPU Fan Replacement, CPU Fan: passo 1, imagem 1 %32
    • Remove the battery by sliding the battery lock switch
  2. Dell XPS 1340 CPU Fan Replacement: passo 2, imagem 1 %32
    • Remove the lower panel of the laptop by loosening 10 screws. Note that the screws do no come out of the back panel.
  3. Dell XPS 1340 CPU Fan Replacement: passo 3, imagem 1 %32
    • Remove two screws which holds a smaller back panel covering only the heatsink
  4. Dell XPS 1340 CPU Fan Replacement: passo 4, imagem 1 %32 Dell XPS 1340 CPU Fan Replacement: passo 4, imagem 2 %32
    • Loosen the four screws on the heat sink for the CPU. Note that these screws don't come out.
    • Now carefully lift the unit from holding the heat pipe.
    • After the heat-pipe unit is removed, the power connector for the fan is accessible.
  5. Dell XPS 1340 CPU Fan Replacement: passo 5, imagem 1 %32 Dell XPS 1340 CPU Fan Replacement: passo 5, imagem 2 %32
    • First remove the power connector for the CPU Fan.
    • Now remove the two screws connecting the CPU Fan.
    • Slowly slide the CPU Fan upwards. It would be a little tight around the edges.
  6. Dell XPS 1340 CPU Fan Replacement: passo 6, imagem 1 %32
    • Unpack the new fan. Make sure the power wires are fixed in the hook provided.
    • Follow all step backwards and finish.
Conclusão
4 outras pessoas executaram este guia.
Paras Tolani
Membro desde: 03/01/13
188 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 2,790
