Introdução
Use this guide to replace the motherboard in the Dell XPS 13.
Ferramentas
Peças
Nenhum componente especificado.
Pull the battery cable connector towards the battery to disconnect it from its socket.
If the connector is stubborn, push a little at one side, then the other, to "walk" it out of its socket.
Open the display and press the power button for five seconds to drain any remaining charge from the system.
Use tweezers to remove the little white connector by pulling it out and away from its socket.
Remove the four 3 mm Phillips #0 screws located on each corner of the battery.
11 outras pessoas concluíram este guia.
