Pular para o conteúdo principal
Introdução
How to replace the mSata SSD drive in a Dell XPS 13 L322X laptop. The images and information in this guide were taken from this computer's service manual, which can be found on the product page.
Peças
Nenhum componente especificado.
  1. After turning off the computer, use a Torx 5 screwdriver to remove the 10 screws (#2) from the computer's base.
    • After turning off the computer, use a Torx 5 screwdriver to remove the 10 screws (#2) from the computer's base.
    • Using a prying tool or a fingernail, lift up the base cover (#1).
  2. Lift up the small latch which holds down the power-light board cable (#3) down. Remove the cable by pulling out sideways.
    • Lift up the small latch which holds down the power-light board cable (#3) down. Remove the cable by pulling out sideways.
    • After removing the Philips screw which holds down the power-light board (#1), remove the power light board (#2) and its cable.
  3. kits de reparo de baterias de iPhone
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  4. Peel the tape that is adhered over the solid-state drive.
    • Peel the tape that is adhered over the solid-state drive.
  5. Remove the screw that secures the solid-state drive to the system board.
    • Remove the screw that secures the solid-state drive to the system board.
    • Slide and remove the solid-state drive out of the system-board connector.
  6. Align the notch on the NEW solid-state drive with the tab in the system-board connector.
    • Align the notch on the NEW solid-state drive with the tab in the system-board connector.
    • CAUTION: Use firm and even pressure to slide the solid-state drive into place. If you use excessive force, you may damage the connector.
    • Insert the solid-state drive connector at a 45-degree angle into the system-board connector.
    • Replace the screw that secures the solid-state drive to the system board.
  7. Adhere the tape over the solid-state drive.
    • Adhere the tape over the solid-state drive.
Conclusão
To reassemble your device, reattatch the power board cable and screw back on the base cover.
Johnathan Hammond
Membro desde: 28-02-2018
35.861 reputação
408 Guias de autoria
Equipe
Informative Technologies Inc. Membro de Informative Technologies Inc.
Community
15 Membros
930 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 23
Todo: 403
