Ir para o conteúdo principal
Dell XPS 13 L321X Mouse pad Replacement
O que você precisa
  1. Dell XPS 13 L321X Mouse pad Replacement, Track Pad: passo 1, imagem 1 %32 Dell XPS 13 L321X Mouse pad Replacement, Track Pad: passo 1, imagem 2 %32
    • Remove ten 3mm screws from the back cover with a T5 screwdriver.
  2. Dell XPS 13 L321X Mouse pad Replacement: passo 2, imagem 1 %32 Dell XPS 13 L321X Mouse pad Replacement: passo 2, imagem 2 %32
    • Disconnect the ribbon cable with a plastic iFixit opening tool, by lifting up the black clip and by pulling the white ribbon off.
    • Pull aside the ribbon cable.
  3. Dell XPS 13 L321X Mouse pad Replacement: passo 3, imagem 1 %32
    • With a plastic iFixit opeing tool, insert it in between and remove the battery cable.
  4. Dell XPS 13 L321X Mouse pad Replacement: passo 4, imagem 1 %32 Dell XPS 13 L321X Mouse pad Replacement: passo 4, imagem 2 %32
    • Use a PH00 size screwdriver to remove the 8 screws that secure the battery.
    • Six 3mm screws.
    • Two 5mm screws.
    • Lift the battery out.
  5. Dell XPS 13 L321X Mouse pad Replacement: passo 5, imagem 1 %32
    • Disconnect the ribbon cable with a plastic iFixit opening tool by lifting up the black clip and by pulling the white ribbon.
    • Place aside.
  6. Dell XPS 13 L321X Mouse pad Replacement: passo 6, imagem 1 %32 Dell XPS 13 L321X Mouse pad Replacement: passo 6, imagem 2 %32 Dell XPS 13 L321X Mouse pad Replacement: passo 6, imagem 3 %32
    • Remove four 2mm screws with a PH00 screwdriver.
    • Remove the mouse pad.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Ahmad EL Herbawi
Membro desde: 03/01/17
499 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team S6-G3, Lacy Spring 2017 Membro de USF Tampa, Team S6-G3, Lacy Spring 2017
USFT-LACY-S17S6G3
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 797
