Ir para o conteúdo principal
Dell XPS 13 Battery Replacement
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
O que você precisa
  1. Dell XPS 13 Battery Replacement, Back Cover: passo 1, imagem 1 %32 Dell XPS 13 Battery Replacement, Back Cover: passo 1, imagem 2 %32
    • Remove the eight 4 mm T5 Torx screws from the bottom cover.
    Missing a step about removing the tiny Phillips head screw under the XPS flip up cover in the middle. Also, there are hooks all the way around the cover so it doesn’t simply lift off.
    curtis_p_brown - Responder
    What about step 3???
    Peter Hecht -
    Please dont hurry , take your Time to follow this procedure. It takes 20 min (not 5) and step 4 requires half of this Time. Good luck.
    Peter Hecht - Responder
    +1 Peter Hecht is right - getting the little clips the back is snapped on with is time consuming and a bit fiddly for people not used to “spudging” off covers. Starting from the back is the key those come loose much easier and help with the rest
    Doug Steinschneider - Responder
  2. Dell XPS 13 Battery Replacement: passo 2, imagem 1 %32 Dell XPS 13 Battery Replacement: passo 2, imagem 2 %32
    • Use a plastic opening tool to pry open the 'XPS' flap in the middle.
    No flap or screw on the XPS 9370, just a press-fit latch at the centre of the cover. This can be gently prised off.
    Alan Thomas - Responder
  3. Dell XPS 13 Battery Replacement: passo 3, imagem 1 %32
    • Remove the single Phillips screw hidden beneath the flap.
    XPS 13 9370 doesn't have it.
    Kes Bond - Responder
  4. Dell XPS 13 Battery Replacement: passo 4, imagem 1 %32
    • Use opening picks or a plastic pry tool to pry open the case clips, beginning from the back edge.
    It’s not that easy to lift actually, cause there are latches. Had t release them gently all around beforehand.
    Davit Barbakadze - Responder
    Also there’s one additional screw under that plate on the bottom!
    Maybe the later models are different, since it should be from the front: https://www.youtube.com/watch?v=xFIE2SKs...
    shigmas - Responder
    Very difficult step, Proceed very carefull
    If you are replacing the battery of a 9360 or latter (2016 onward) make sure to do the FRONT first. There are latches on the back that you may break if you try to force it open that way. After prying up the front and the sides, just lift up the front like you would open a hinged box. You shouldn’t feel that much resistance as the back hinges off towards you after you’ve lifted it around 30-40 degrees.
    Giacomo P - Responder
    Very easy with XPS 13 9370 - just used my nails (rather short!)
  5. Dell XPS 13 Battery Replacement: passo 5, imagem 1 %32
    • Remove the bottom cover.
    good evening, is there a site that sells the back part because it's broken
    marios cocka - Responder
  6. Dell XPS 13 Battery Replacement, Battery: passo 6, imagem 1 %32 Dell XPS 13 Battery Replacement, Battery: passo 6, imagem 2 %32
    • Remove the four 3 mm Phillips #0 screws located on each corner of the battery.
    There are two additional screws holding sound speakers.
    And there is a another small screw holding the battery right above the “M1 6x4” print.
    You also do not need to remove any speaker screws or the speaker, you just have to remove the tape holding the speaker wire to the battery.
  7. Dell XPS 13 Battery Replacement: passo 7, imagem 1 %32 Dell XPS 13 Battery Replacement: passo 7, imagem 2 %32
    • Pull the battery cable connector towards the battery to disconnect it from its socket.
    • Do not pull up.
    This is a redundant step (disconnect the battery in step 6).
    William Cummings - Responder
  8. Dell XPS 13 Battery Replacement: passo 8, imagem 1 %32
    • Peel up any tape securing the speaker cables to the battery.
    • You do not need to remove the speakers, only the tape, allowing the battery to be removed out under the speaker cables.
  9. Dell XPS 13 Battery Replacement: passo 9, imagem 1 %32
    • Remove the battery.
Conclusão
23 outras pessoas executaram este guia.
Ella Herrmann
Membro desde: 04/24/17
1.588 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S21-G6, Livingston Spring 2017 Membro de Cal Poly, Team S21-G6, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G6
Membros da 5
Autoria de 30 guias
6 comentários
There is a #00 Phillips under the XPS cover on the bottom. Also one of the #0 screws holding the battery down is #00. It is not necessary to remove the speakers but the wires are taped to the battery so pick and remove the tape.
scott Brawner - Responder
Took me about 45 minutes.
Couple of complexities:
1. The speaker removal, it’s easier just to unscrew and pull out that way. Moreover, it’s easier the same way to replace, the problem is if you push in the speakers can remain wobbly unless you properly attach to the flexible plastic things.
2. When replacing the screws on the battery, do the little screw first. It shows it on the images, but doesn’t mention it, it’s a different sized screw (step 3).
3. Removing the screws on the back of the laptop is tough unless you have a good screw driver. In the end, I bought one from China from Aliexpress that was bang on what I needed.
Daniel Offer - Responder
Does anyone have a source for a replacement battery? I checked Amazon but reviews were sketchy at best.
Andrew Chervenak - Responder
I was concerned about the Amazon reviews as well. I ordered my battery directly from Dell for $85.
Samuel Adams -
Great guide! Came in real handy when I needed to replace a swollen battery.
Although the speaker removal part can be skipped completely.
Just remove the 4 Philip battery screws and peel off the black tapes securing the red/white speaker wires would be sufficient to allow the battery to slide right off.
Michael Wu - Responder
Excellent guide. It took me about 20 minutes and I’m a complete novice to this stuff. I didn’t need to lift the speakers at all.
I got my battery from Duracell Direct (UK), for half the price Dell were charging and thanks to this guide giving me confidence I’ve made the change early enough that my keyboard has dropped straight back into shape and isn’t deformed any more. Am very happy. Thanks
MaddyL - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 20,093
