Ir para o conteúdo principal
Dell XPS 13 9370 Battery Replacement
O que você precisa
    • Save and close all open files and exit all open applications.
    • Shut down your computer. Click Start > Power > Shut down.
    • Disconnect your computer and all attached devices from their electrical outlets.
    • Disconnect all attached network devices and peripherals, such as keyboard, mouse, and monitor from your computer.
    • Remove any media card and optical disc from your computer, if applicable.
  1. Dell XPS 13 9370 Battery Replacement, Remove the base cover screws: passo 2, imagem 1 %32
    • Remove the eight screws (M2x3, Torx) that secure the base cover to the palm-rest assembly.
  2. Dell XPS 13 9370 Battery Replacement, Remove the base cover: passo 3, imagem 1 %32 Dell XPS 13 9370 Battery Replacement, Remove the base cover: passo 3, imagem 2 %32
    • With the computer face-down, open the computer at an angle.
    • Using a plastic scribe (spudger), pry the base cover from the palm-rest assembly.
    • Moving the base cover from left to right, release the clips securing the base cover to the palm-rest assembly.
    • Lift the base cover from the palm-rest assembly.
  3. Dell XPS 13 9370 Battery Replacement, Disconnect battery cable: passo 4, imagem 1 %32
    • Disconnect the battery cable from the system board.
  4. Dell XPS 13 9370 Battery Replacement, Remove the battery: passo 5, imagem 1 %32
    • Remove the four screws (M2x2) that secure the battery to the palm-rest assembly.
    • Remove the screw (M1.6x4) that secures the battery to the palm-rest assembly.
    • Lift the battery off the palm-rest assembly.
    • Turn the computer over, open the display, and press the power button for about 5 seconds to ground the computer.
Conclusão
To replace the battery & reassemble your device, follow these instructions in reverse order.
23 outras pessoas executaram este guia.
Max Kletskov
Membro desde: 04/22/20
40.298 Reputação
Autoria de 16 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 17.198 guias
8 comentários
Is the battery an original dell battery?
mnyousafva - Responder
Why doesn’t it say what tools are needed?
Noah Guirguis - Responder
Excellent guide. Took me about 25 minutes. Works perfectly.
Jeff Doremus - Responder
Instructions were perfect, thanks for the great guide!
surfdaworld - Responder
Boom, in a good way! I fixed it!
Chris Cox - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 11
Últimos 7 dias: 92
Últimos 30 dias: 500
Duração total: 15,293
