Ir para o conteúdo principal
Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement
O que você precisa
  1. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement, Battery: passo 1, imagem 1 %32
    • Use a Torx T4 screwdriver to remove the eight screws (M2x3) that secure the base cover to the palm-rest assembly.
  2. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement: passo 2, imagem 1 %32
    • Use your fingertips to lift the system badge open and reveal the single case screw.
    • Use a Phillips #000 screwdriver to remove the screw (M1.6x4) that secures the base cover to the palm-rest assembly.
  3. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement: passo 3, imagem 1 %32
    • Starting from the front corner of the computer, pry up the base cover using a spudger and lift the base cover off the palm-rest assembly.
  4. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement: passo 4, imagem 1 %32
    • Disconnect the battery cable from the system board.
  5. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement: passo 5, imagem 1 %32
    • Use a Phillips #000 screwdriver to remove the two screws (M1.6x4) that secure the battery to the palm-rest assembly.
  6. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement: passo 6, imagem 1 %32
    • Use a Phillips #000 screwdriver to remove the six screws (M2x3) that secure the battery to the palm-rest assembly.
  7. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement: passo 7, imagem 1 %32
    • Lift the battery off the palm-rest assembly.
  8. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement, Removing the Solid-State Drive: passo 8, imagem 1 %32
    • Peel off the display cable tape from the hard-drive plate.
  9. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement: passo 9, imagem 1 %32
    • Remove the two screws (M1.6x2.5) that secure the hard-drive plate to the system board with a Phillips 000 screwdriver head.
  10. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement: passo 10, imagem 1 %32
    • Remove the hard-drive plate.
  11. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement: passo 11, imagem 1 %32
    • Gently slide and remove the solid-state drive from the solid-state drive slot (SSD not pictured in image).
    • Solid-state drives are fragile. Exercise care when handling the solid-state drive.
Conclusão
Johnathan Hammond
Membro desde: 02/28/18
44.830 Reputação
Autoria de 408 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 57
Duração total: 5,975
