Ir para o conteúdo principal
Dell XPS 13 9365 2-in-1 Touchpad Replacement
O que você precisa
  1. Dell XPS 13 9365 2-in-1 Touchpad Replacement, Battery: passo 1, imagem 1 %32
    • Use a Torx T4 screwdriver to remove the eight screws (M2x3) that secure the base cover to the palm-rest assembly.
  2. Dell XPS 13 9365 2-in-1 Touchpad Replacement: passo 2, imagem 1 %32
    • Use your fingertips to lift the system badge open and reveal the single case screw.
    • Use a Phillips #000 screwdriver to remove the screw (M1.6x4) that secures the base cover to the palm-rest assembly.
  3. Dell XPS 13 9365 2-in-1 Touchpad Replacement: passo 3, imagem 1 %32
    • Starting from the front corner of the computer, pry up the base cover using a spudger and lift the base cover off the palm-rest assembly.
  4. Dell XPS 13 9365 2-in-1 Touchpad Replacement: passo 4, imagem 1 %32
    • Disconnect the battery cable from the system board.
  5. Dell XPS 13 9365 2-in-1 Touchpad Replacement: passo 5, imagem 1 %32
    • Use a Phillips #000 screwdriver to remove the two screws (M1.6x4) that secure the battery to the palm-rest assembly.
  6. Dell XPS 13 9365 2-in-1 Touchpad Replacement: passo 6, imagem 1 %32
    • Use a Phillips #000 screwdriver to remove the six screws (M2x3) that secure the battery to the palm-rest assembly.
  7. Dell XPS 13 9365 2-in-1 Touchpad Replacement: passo 7, imagem 1 %32
    • Lift the battery off the palm-rest assembly.
  8. Dell XPS 13 9365 2-in-1 Touchpad Replacement, Touchpad: passo 8, imagem 1 %32 Dell XPS 13 9365 2-in-1 Touchpad Replacement, Touchpad: passo 8, imagem 2 %32 Dell XPS 13 9365 2-in-1 Touchpad Replacement, Touchpad: passo 8, imagem 3 %32
    • Open the ZIF latch on the touch pad connector.
    • Disconnect and remove the ribbon cable from the touch pad. The ZIF connector latch lifts up to allow its release.
  9. Dell XPS 13 9365 2-in-1 Touchpad Replacement: passo 9, imagem 1 %32
    • Use a Phillips #000 screwdriver to remove the two screws (M2x2) that secure the touch pad to the palm-rest assembly.
  10. Dell XPS 13 9365 2-in-1 Touchpad Replacement: passo 10, imagem 1 %32 Dell XPS 13 9365 2-in-1 Touchpad Replacement: passo 10, imagem 2 %32
    • Lift the touch pad from the inner edge and remove it from the palm-rest assembly.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 8
Últimos 30 dias: 41
Duração total: 682
