Ir para o conteúdo principal
Dell XPS 13 9365 2-in-1 Speakers Replacement
O que você precisa
  1. Dell XPS 13 9365 2-in-1 Speakers Replacement, Battery: passo 1, imagem 1 %32
    • Use a Torx T4 screwdriver to remove the eight screws (M2x3) that secure the base cover to the palm-rest assembly.
  2. Dell XPS 13 9365 2-in-1 Speakers Replacement: passo 2, imagem 1 %32
    • Use your fingertips to lift the system badge open and reveal the single case screw.
    • Use a Phillips #000 screwdriver to remove the screw (M1.6x4) that secures the base cover to the palm-rest assembly.
  3. Dell XPS 13 9365 2-in-1 Speakers Replacement: passo 3, imagem 1 %32
    • Starting from the front corner of the computer, pry up the base cover using a spudger and lift the base cover off the palm-rest assembly.
  4. Dell XPS 13 9365 2-in-1 Speakers Replacement: passo 4, imagem 1 %32
    • Disconnect the battery cable from the system board.
  5. Dell XPS 13 9365 2-in-1 Speakers Replacement: passo 5, imagem 1 %32
    • Use a Phillips #000 screwdriver to remove the two screws (M1.6x4) that secure the battery to the palm-rest assembly.
  6. Dell XPS 13 9365 2-in-1 Speakers Replacement: passo 6, imagem 1 %32
    • Use a Phillips #000 screwdriver to remove the six screws (M2x3) that secure the battery to the palm-rest assembly.
  7. Dell XPS 13 9365 2-in-1 Speakers Replacement: passo 7, imagem 1 %32
    • Lift the battery off the palm-rest assembly.
  8. Dell XPS 13 9365 2-in-1 Speakers Replacement, Speakers: passo 8, imagem 1 %32
    • Peel off the tape securing the speaker cable to the system board.
  9. Dell XPS 13 9365 2-in-1 Speakers Replacement: passo 9, imagem 1 %32
    • Disconnect the speaker cable from the motherboard.
  10. Dell XPS 13 9365 2-in-1 Speakers Replacement: passo 10, imagem 1 %32
    • Note the speaker-cable routing and peel off the tape that secures the speaker cable to the system board.
  11. Dell XPS 13 9365 2-in-1 Speakers Replacement: passo 11, imagem 1 %32 Dell XPS 13 9365 2-in-1 Speakers Replacement: passo 11, imagem 2 %32
    • Use a Phillips #000 screwdriver to remove the four screws (M2x2) that secure the speakers to the palm-rest assembly.
  12. Dell XPS 13 9365 2-in-1 Speakers Replacement: passo 12, imagem 1 %32
    • Lift the speakers, along with its cables, off the palm-rest assembly.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 24
Duração total: 479
