Ir para o conteúdo principal
Dell XPS 13 Track Pad Replacement
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
O que você precisa
  1. Dell XPS 13 Track Pad Replacement, Back Cover: passo 1, imagem 1 %32 Dell XPS 13 Track Pad Replacement, Back Cover: passo 1, imagem 2 %32
    • Remove the eight 4 mm T5 Torx screws from the bottom cover.
  2. Dell XPS 13 Track Pad Replacement: passo 2, imagem 1 %32 Dell XPS 13 Track Pad Replacement: passo 2, imagem 2 %32
    • Use a plastic opening tool to pry open the 'XPS' flap in the middle.
  3. Dell XPS 13 Track Pad Replacement: passo 3, imagem 1 %32
    • Remove the single Phillips screw hidden beneath the flap.
  4. Dell XPS 13 Track Pad Replacement: passo 4, imagem 1 %32
    • Use opening picks or a plastic pry tool to pry open the case clips, beginning from the back edge.
  5. Dell XPS 13 Track Pad Replacement: passo 5, imagem 1 %32
    • Remove the bottom cover.
  6. Dell XPS 13 Track Pad Replacement, Battery Disconnection: passo 6, imagem 1 %32 Dell XPS 13 Track Pad Replacement, Battery Disconnection: passo 6, imagem 2 %32
    • Pull the battery cable connector towards the battery to disconnect it from its socket.
    • If the connector is stubborn, push a little at one side, then the other, to "walk" it out of its socket.
    • If you have trouble walking the connector out of the socket, use the point of a spudger to gently push on the connector indent to slide the connector out.
    • Do not pull up.
    • Open the display and press the power button for five seconds to drain any remaining charge from the system.
  7. Dell XPS 13 Track Pad Replacement, Battery: passo 7, imagem 1 %32 Dell XPS 13 Track Pad Replacement, Battery: passo 7, imagem 2 %32
    • Remove the four 3 mm Phillips #0 screws located on each corner of the battery.
  8. Dell XPS 13 Track Pad Replacement: passo 8, imagem 1 %32 Dell XPS 13 Track Pad Replacement: passo 8, imagem 2 %32
    • Do not pull up.
  9. Dell XPS 13 Track Pad Replacement: passo 9, imagem 1 %32
    • Peel up any tape securing the speaker cables to the battery.
    • You do not need to remove the speakers, only the tape, allowing the battery to be removed out under the speaker cables.
  10. Dell XPS 13 Track Pad Replacement: passo 10, imagem 1 %32
    • Remove the battery.
  11. Dell XPS 13 Track Pad Replacement, Track Pad: passo 11, imagem 1 %32 Dell XPS 13 Track Pad Replacement, Track Pad: passo 11, imagem 2 %32
    • Remove the four 3 mm Phillips #1 screws from the trackpad.
  12. Dell XPS 13 Track Pad Replacement: passo 12, imagem 1 %32
    • Use tweezers to gently lift the upper-right corner of the track pad.
    • Remove the track pad by slowly pulling it up and away from you.
Conclusão
4 outras pessoas executaram este guia.
Arvind Krish
Membro desde: 04/26/17
179 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S21-G6, Livingston Spring 2017 Membro de Cal Poly, Team S21-G6, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G6
Membros da 5
Autoria de 30 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 39
Últimos 30 dias: 141
Duração total: 13,296
