Ir para o conteúdo principal
Dell XPS 15 Motherboard Replacement
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
O que você precisa
  1. Dell XPS 15 Motherboard Replacement, Back Cover: passo 1, imagem 1 %32 Dell XPS 15 Motherboard Replacement, Back Cover: passo 1, imagem 2 %32
    • Remove the eight 4 mm T5 Torx screws from the bottom cover.
  2. Dell XPS 15 Motherboard Replacement: passo 2, imagem 1 %32 Dell XPS 15 Motherboard Replacement: passo 2, imagem 2 %32
    • Use a plastic opening tool to pry open the 'XPS' flap in the middle.
  3. Dell XPS 15 Motherboard Replacement: passo 3, imagem 1 %32
    • Remove the single Phillips screw hidden beneath the flap.
  4. Dell XPS 15 Motherboard Replacement: passo 4, imagem 1 %32
    • Use opening picks or a plastic pry tool to pry open the case clips, beginning from the back edge.
  5. Dell XPS 15 Motherboard Replacement: passo 5, imagem 1 %32
    • Remove the bottom cover.
  6. Dell XPS 15 Motherboard Replacement, Battery Disconnection: passo 6, imagem 1 %32 Dell XPS 15 Motherboard Replacement, Battery Disconnection: passo 6, imagem 2 %32
    • Pull the battery cable connector towards the battery to disconnect it from its socket.
    • If the connector is stubborn, push a little at one side, then the other, to "walk" it out of its socket.
    • If you have trouble walking the connector out of the socket, use the point of a spudger to gently push on the connector indent to slide the connector out.
    • Do not pull up.
    • Open the display and press the power button for five seconds to drain any remaining charge from the system.
  7. Dell XPS 15 Motherboard Replacement, Fan: passo 7, imagem 1 %32 Dell XPS 15 Motherboard Replacement, Fan: passo 7, imagem 2 %32 Dell XPS 15 Motherboard Replacement, Fan: passo 7, imagem 3 %32
    • Use tweezers to remove the little white connector by pulling it out and away from its socket.
  8. Dell XPS 15 Motherboard Replacement: passo 8, imagem 1 %32 Dell XPS 15 Motherboard Replacement: passo 8, imagem 2 %32
    • Remove the black standard flat connector by lifting the tab up with your hand.
  9. Dell XPS 15 Motherboard Replacement: passo 9, imagem 1 %32 Dell XPS 15 Motherboard Replacement: passo 9, imagem 2 %32
    • Remove the 4 mm Phillips #0 screw that connects the fan to the motherboard.
    • Remove the 4 mm Phillips #0 screw that connects the fan to the base of the computer.
  10. Dell XPS 15 Motherboard Replacement: passo 10, imagem 1 %32 Dell XPS 15 Motherboard Replacement: passo 10, imagem 2 %32
    • Use your right hand to lift up the larger section of the motherboard, closest to the fan.
    • Use your left hand to pull the fan at a 30-degree angle out from underneath the motherboard.
  11. Dell XPS 15 Motherboard Replacement, Battery: passo 11, imagem 1 %32 Dell XPS 15 Motherboard Replacement, Battery: passo 11, imagem 2 %32
    • Remove the four 3 mm Phillips #0 screws located on each corner of the battery.
  12. Dell XPS 15 Motherboard Replacement: passo 12, imagem 1 %32 Dell XPS 15 Motherboard Replacement: passo 12, imagem 2 %32
    • Do not pull up.
  13. Dell XPS 15 Motherboard Replacement: passo 13, imagem 1 %32
    • Peel up any tape securing the speaker cables to the battery.
    • You do not need to remove the speakers, only the tape, allowing the battery to be removed out under the speaker cables.
  14. Dell XPS 15 Motherboard Replacement: passo 14, imagem 1 %32
    • Remove the battery.
  15. Dell XPS 15 Motherboard Replacement, Motherboard: passo 15, imagem 1 %32 Dell XPS 15 Motherboard Replacement, Motherboard: passo 15, imagem 2 %32
    • Remove the eight 4 mm Phillips #0 screws from the motherboard.
  16. Dell XPS 15 Motherboard Replacement: passo 16, imagem 1 %32 Dell XPS 15 Motherboard Replacement: passo 16, imagem 2 %32 Dell XPS 15 Motherboard Replacement: passo 16, imagem 3 %32
    • Locate the red and black cable connector at the bottom right of the motherboard.
    • Use tweezers to slowly detach the cable connector from its socket by pulling it to the right and up.
  17. Dell XPS 15 Motherboard Replacement: passo 17, imagem 1 %32 Dell XPS 15 Motherboard Replacement: passo 17, imagem 2 %32 Dell XPS 15 Motherboard Replacement: passo 17, imagem 3 %32
    • Use tweezers to flip open the Zero Insertion Force (ZIF) connector.
    • Use tweezers to detach the ribbon cable from the ZIF by pulling it towards yourself.
  18. Dell XPS 15 Motherboard Replacement: passo 18, imagem 1 %32 Dell XPS 15 Motherboard Replacement: passo 18, imagem 2 %32 Dell XPS 15 Motherboard Replacement: passo 18, imagem 3 %32
    • Use tweezers to flip open the white ZIF connector.
    • Use tweezers to detach the ribbon connector from the ZIF by pulling it towards yourself.
  19. Dell XPS 15 Motherboard Replacement: passo 19, imagem 1 %32 Dell XPS 15 Motherboard Replacement: passo 19, imagem 2 %32 Dell XPS 15 Motherboard Replacement: passo 19, imagem 3 %32
    • Use tweezers to flip open the ZIF connector.
    • Use tweezers to detach the orange ribbon connector from the ZIF by pulling it towards yourself.
  20. Dell XPS 15 Motherboard Replacement: passo 20, imagem 1 %32 Dell XPS 15 Motherboard Replacement: passo 20, imagem 2 %32
    • Use tweezers to detach the black cable connector out of its socket by pulling it to the right.
  21. Dell XPS 15 Motherboard Replacement: passo 21, imagem 1 %32 Dell XPS 15 Motherboard Replacement: passo 21, imagem 2 %32 Dell XPS 15 Motherboard Replacement: passo 21, imagem 3 %32
    • Use tweezers to gently detach the black and white cable connector out of its socket by pulling it to the right.
  22. Dell XPS 15 Motherboard Replacement: passo 22, imagem 1 %32 Dell XPS 15 Motherboard Replacement: passo 22, imagem 2 %32
    • Locate the connector at the top right of the motherboard.
    • Use tweezers to detach the cable connector from its socket by pulling it to the right.
  23. Dell XPS 15 Motherboard Replacement: passo 23, imagem 1 %32 Dell XPS 15 Motherboard Replacement: passo 23, imagem 2 %32 Dell XPS 15 Motherboard Replacement: passo 23, imagem 3 %32
    • Locate the last black cable connector.
    • Use tweezers to detach the black cable connector from its socket by pulling it to the right.
  24. Dell XPS 15 Motherboard Replacement: passo 24, imagem 1 %32
    • Use your hands to lift up the motherboard.
Conclusão
12 outras pessoas executaram este guia.
Evan Shui
Membro desde: 04/26/17
320 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S21-G6, Livingston Spring 2017 Membro de Cal Poly, Team S21-G6, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G6
Membros da 5
Autoria de 30 guias
2 comentários
where is camera cable
phong thanh - Responder
Wow man that is awesome job. Where can you get a newer motheboard for the same laptop?
R E - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 21
Últimos 30 dias: 182
Duração total: 23,724
