Ir para o conteúdo principal
Dell XPS 12 9Q33 mSATA Card Replacement
O que você precisa
  1. Dell XPS 12 9Q33 mSATA Card Replacement, Removing the Battery: passo 1, imagem 1 %32
    • Slide the battery cable connector out of its system board socket.
    • Pull parallel to the motherboard, not straight up, or you will damage the socket.
    • Remove the screws that secure the battery to the palm-rest assembly.
    • Lift and remove the battery along with its cable.
    • Slide and hold the power switch for about five seconds to ground the system board.
  2. Dell XPS 12 9Q33 mSATA Card Replacement, Removing the mSATA card: passo 2, imagem 1 %32
    • Remove the screw that secures the mSATA card to the system board.
    • Slide and remove the mSATA card out of the mSATA-card connector.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
Conclusão
3 outras pessoas executaram este guia.
Johnathan Hammond
Membro desde: 02/28/18
44.953 Reputação
Autoria de 408 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.986 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 374
