Ir para o conteúdo principal
Dell XPS 12 9Q23 Touch Pad Replacement
O que você precisa
  1. Dell XPS 12 9Q23 Touch Pad Replacement, Battery: passo 1, imagem 1 %32
    • Pop the center cover open on the bottom cover.
    • Remove the center screw with a #00 Phillips screwdriver.
    • Use a T5 Torx screwdriver for the remaining screws around the edge of the bottom cover.
  2. Dell XPS 12 9Q23 Touch Pad Replacement: passo 2, imagem 1 %32
    • Carefully remove back panel after all screws have been removed.
  3. Dell XPS 12 9Q23 Touch Pad Replacement: passo 3, imagem 1 %32
    • After the back panel has been removed, disconnect the battery to prevent electrical shock
  4. Dell XPS 12 9Q23 Touch Pad Replacement: passo 4, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove the 8 screws that secure the battery.
  5. Dell XPS 12 9Q23 Touch Pad Replacement, Remove the battery: passo 5, imagem 1 %32
    • Once all the screws have been removed the battery is now safe to extract
  6. Dell XPS 12 9Q23 Touch Pad Replacement, Touch Pad: passo 6, imagem 1 %32
    • Unplug the trackpad cable.
  7. Dell XPS 12 9Q23 Touch Pad Replacement: passo 7, imagem 1 %32
    • Insert wisdom here.
  8. Dell XPS 12 9Q23 Touch Pad Replacement: passo 8, imagem 1 %32
    • Use a Phillips screwdriver to remove the 4 trackpad screws.
  9. Dell XPS 12 9Q23 Touch Pad Replacement: passo 9, imagem 1 %32
    • Remove the trackpad.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 13
Duração total: 1,637
