Introdução
Dell XPS 12 9Q23 Battery Replacement is a guide that focuses on replacing a dell charger easily without getting hurt.If you want to know how to successfully replace a Dell battery this guide is good for instructing you.This repair might be needed when you need to recharge or replace your battery. Genuine Dell XPS 12 9Q23 12.5" Battery 7.4V 47WH 6128mAh 77G21 Y9N00 Is a Dell replacement you can use.
O que você precisa
Pop the center cover open on the bottom cover.
Remove the center screw with a #00 Phillips screwdriver.
Use a T5 Torx screwdriver for the remaining screws around the edge of the bottom cover.
Carefully remove back panel after all screws have been removed.
I suggest sliding an opening tool along the front of the case first to pop the plastic snaps holding the cover to the bottom of the laptop. The snaps near the hinges are the most challenging. It is also important, when following these directions in reverse order, to fit the right side of the case over the sliding power switch before applying downward pressure required to snap the case bottom back into place. Wouldn’t want to break your power switch.
Once all the screws have been removed the battery is now safe to extract
5 outras pessoas executaram este guia.
2 comentários
Any tips for registering the new battery in the BIOS?
Your battery is automatically recognized.
There is no declaration to be made in the bios.
If the problem persists, I invite you to open a support question:
