Ir para o conteúdo principal
Dell XPS 12 9Q23 Battery Replacement
O que você precisa
  1. Dell XPS 12 9Q23 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Pop the center cover open on the bottom cover.
    • Remove the center screw with a #00 Phillips screwdriver.
    • Use a T5 Torx screwdriver for the remaining screws around the edge of the bottom cover.
  2. Dell XPS 12 9Q23 Battery Replacement: passo 2, imagem 1 %32
    • Carefully remove back panel after all screws have been removed.
  3. Dell XPS 12 9Q23 Battery Replacement: passo 3, imagem 1 %32
    • After the back panel has been removed, disconnect the battery to prevent electrical shock
  4. Dell XPS 12 9Q23 Battery Replacement: passo 4, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove the 8 screws that secure the battery.
  5. Dell XPS 12 9Q23 Battery Replacement, Remove the battery: passo 5, imagem 1 %32
    • Once all the screws have been removed the battery is now safe to extract
Conclusão
5 outras pessoas executaram este guia.
2 comentários
Any tips for registering the new battery in the BIOS?
Ryan Porter - Responder
Your battery is automatically recognized.
There is no declaration to be made in the bios.
If the problem persists, I invite you to open a support question:
https://fr.ifixit.com/R%C3%A9ponses/Devi...
Schwarzer -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 40
Duração total: 4,411
