Ir para o conteúdo principal
Dell XPS 10 Battery Replacement
O que você precisa
  1. Dell XPS 10 Battery Replacement, Battery: passo 1, imagem 1 %32 Dell XPS 10 Battery Replacement, Battery: passo 1, imagem 2 %32 Dell XPS 10 Battery Replacement, Battery: passo 1, imagem 3 %32
    • Slide one of the plastic opening tools in the crack on the side of the device with the windows button.
    • Slide the other plastic opening tool facing the opposite way in the crack next to the first one and pry the back cover off a little bit at a time or slide them around the edge as necessary.
    • Finally, slide the two plastic opening tools all around the case until it is open.
  2. Dell XPS 10 Battery Replacement: passo 2, imagem 1 %32 Dell XPS 10 Battery Replacement: passo 2, imagem 2 %32 Dell XPS 10 Battery Replacement: passo 2, imagem 3 %32
    • Unscrew the three black, 4mm screws with a phillips screwdriver size PH 0 (one of which is under the gold colored ribbon cable.)
    • Unscrew the three gray, 3mm screws with the same screwdriver (phillips screwdriver size PH 0.)
    • Unplug the connector the connects the battery to the mother board.
    • Make sure to use a plastic opening tool instead of a metal spudger to avoid any unnecessary accidental shorting out of components.
Conclusão
saraspam
Membro desde: 09/28/16
244 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 2-1, Nance Fall 2016 Membro de USF Tampa, Team 2-1, Nance Fall 2016
USFT-NANCE-F16S2G1
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 17
Duração total: 3,121
