Ir para o conteúdo principal
Dell Wyse Xn0m Mouse Sensor Board Replacement
O que você precisa
  1. Dell Wyse Xn0m Mouse Sensor Board Replacement, Mouse Sensor Board: passo 1, imagem 1 %32
    • Flip the device over. Unscrew nine marked 7mm Phillips #1 screws.
  2. Dell Wyse Xn0m Mouse Sensor Board Replacement: passo 2, imagem 1 %32 Dell Wyse Xn0m Mouse Sensor Board Replacement: passo 2, imagem 2 %32
    • Remove the keyboard by pushing back the tabs at the marked locations with a spudger or plastic opening tool.
  3. Dell Wyse Xn0m Mouse Sensor Board Replacement: passo 3, imagem 1 %32 Dell Wyse Xn0m Mouse Sensor Board Replacement: passo 3, imagem 2 %32
    • Turn the device around so the screen is closest to you. Lift the keyboard and detach the ribbon cable with the spudger.
    • To disconnect the cable, disengage the locking tab of the ZIF connector with the spudger and pull the cable out gently.
  4. Dell Wyse Xn0m Mouse Sensor Board Replacement: passo 4, imagem 1 %32
    • Remove the keyboard and set it aside. Detach the other ribbon cables with the spudger.
    • Remove five 8mm Phillips #1 screws.
  5. Dell Wyse Xn0m Mouse Sensor Board Replacement: passo 5, imagem 1 %32
    • Pry open the laptop with the plastic opening tool.
  6. Dell Wyse Xn0m Mouse Sensor Board Replacement: passo 6, imagem 1 %32 Dell Wyse Xn0m Mouse Sensor Board Replacement: passo 6, imagem 2 %32
    • Under the trackpad, detach the ribbon cables with the spudger.
    • Unscrew two 3mm Phillips #1 screws and lift the board from the pegs.
    • Remove the board from the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 18
Duração total: 613
