Pular para o conteúdo principal
Introdução
In this guide, we will show you how to remove and replace the LED Cover.
Peças
Nenhum componente especificado.
  1. Remove the screws that secure the base cover to the computer.
    • Remove the screws that secure the base cover to the computer.
  2. Slide the base cover towards the front of the computer. Lift it up and away from the computer.
    • Slide the base cover towards the front of the computer. Lift it up and away from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  3. Lift the black cable-release clip to release the battery cable from the connector on the system board and disconnect the battery cable.
    • Lift the black cable-release clip to release the battery cable from the connector on the system board and disconnect the battery cable.
  4. Kit de Reparo de Bateria do MacBook
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  5. Remove the screws that secure the battery to the computer.
    • Remove the screws that secure the battery to the computer.
  6. Lift the battery up and away from the computer.
    • Lift the battery up and away from the computer.
  7. Starting on the right side of the system, use a plastic scribe to pry up the LED cover from the computer.
    • Starting on the right side of the system, use a plastic scribe to pry up the LED cover from the computer.
  8. Pull the LED cover toward the keyboard and remove it from the computer.
    • Pull the LED cover toward the keyboard and remove it from the computer.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Johnathan Hammond
Membro desde: 28-02-2018
35.861 reputação
408 Guias de autoria
Equipe
Informative Technologies Inc. Membro de Informative Technologies Inc.
Community
15 Membros
925 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Todo: 31
