Introdução
In this guide, we will be showing you how to remove the Hard Drive and Audio Board.
O que você precisa
Slide the base cover towards the front of the computer. Lift it up and away from the computer.
If this is all you are doing Follow Step In Reverse if not Go to Next Step.
Lift the black cable-release clip to release the battery cable from the connector on the system board and disconnect the battery cable.
Disconnect the speaker and system board cables from the audio board.
Remove the screws that secure the audio board and the hard drive to the computer.
Lift and remove the hard drive and audio board assembly from the computer.
Remove the screws that secure the hard-drive bracket to the hard drive.
Uma outra pessoa concluiu este guia.
