Ir para o conteúdo principal
Dell Vostro V130 Hard Drive and Audio Board Removal
O que você precisa
  1. Dell Vostro V130 Hard Drive and Audio Board Removal, Remove the Screws: passo 1, imagem 1 %32
    • Remove the screws that secure the base cover to the computer.
  2. Dell Vostro V130 Hard Drive and Audio Board Removal, Removing the Base Cover: passo 2, imagem 1 %32
    • Slide the base cover towards the front of the computer. Lift it up and away from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  3. Dell Vostro V130 Hard Drive and Audio Board Removal, Disconnecting the Battery: passo 3, imagem 1 %32
    • Lift the black cable-release clip to release the battery cable from the connector on the system board and disconnect the battery cable.
  4. Dell Vostro V130 Hard Drive and Audio Board Removal, Remove Battery Screws: passo 4, imagem 1 %32
    • Remove the screws that secure the battery to the computer.
  5. Dell Vostro V130 Hard Drive and Audio Board Removal, Lift the Battery: passo 5, imagem 1 %32
    • Lift the battery up and away from the computer.
  6. Dell Vostro V130 Hard Drive and Audio Board Removal, Disconnecting the Speaker: passo 6, imagem 1 %32
    • Disconnect the speaker and system board cables from the audio board.
  7. Dell Vostro V130 Hard Drive and Audio Board Removal, Remove the Screws: passo 7, imagem 1 %32
    • Remove the screws that secure the audio board and the hard drive to the computer.
  8. Dell Vostro V130 Hard Drive and Audio Board Removal, Lifting the Hard Drive and Audio Board: passo 8, imagem 1 %32
    • Lift and remove the hard drive and audio board assembly from the computer.
  9. Dell Vostro V130 Hard Drive and Audio Board Removal, Sliding the Audio Board: passo 9, imagem 1 %32
    • Slide the audio board from the hard drive.
  10. Dell Vostro V130 Hard Drive and Audio Board Removal, Remove the Screws: passo 10, imagem 1 %32
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  11. Dell Vostro V130 Hard Drive and Audio Board Removal, Removing the Hard Drive: passo 11, imagem 1 %32
    • Remove the hard drive from the hard-drive bracket.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Johnathan Hammond
Membro desde: 02/28/18
44.953 Reputação
Autoria de 408 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.986 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 13
Duração total: 575
