Introdução
You can follow these steps to replace the sound card in your Dell Vostro V13. Be sure to power down, unplug and also back-up your laptop in order to prevent injury and loss of data.
O que você precisa
Flip the laptop over so the vents are facing you.
Remove the six 5.0 mm Phillips #1 screws using the magnetic driver.
Remove the two 5.0 mm Phillips #1 screws on the back side of the laptop.
Remove the black 3.0 mm Phillips #1 screw.
Remove the two 5.1 mm silver Phillips #1 screws.
Conclusão
