Introdução
If your keyboard is unresponsive, you may need to replace it. You can follow these steps to replace it properly.
O que você precisa
Flip the laptop over so the vents are facing you.
Remove the six 5.0 mm Phillips #1 screws using the magnetic driver.
Remove the two 5.0 mm Phillips #1 screws on the back side of the laptop.
Quase terminado!
Conclusão
