Ir para o conteúdo principal
Dell Vostro V13 Keyboard Replacement
O que você precisa
  1. Dell Vostro V13 Keyboard Replacement, Back Cover: passo 1, imagem 1 %32 Dell Vostro V13 Keyboard Replacement, Back Cover: passo 1, imagem 2 %32 Dell Vostro V13 Keyboard Replacement, Back Cover: passo 1, imagem 3 %32
    • Back up the memory to an external drive and power off the laptop before starting.
    • Flip the laptop over so the vents are facing you.
    • Remove the six 5.0 mm Phillips #1 screws using the magnetic driver.
    • Remove the two 5.0 mm Phillips #1 screws on the back side of the laptop.
  2. Dell Vostro V13 Keyboard Replacement: passo 2, imagem 1 %32 Dell Vostro V13 Keyboard Replacement: passo 2, imagem 2 %32 Dell Vostro V13 Keyboard Replacement: passo 2, imagem 3 %32
    • Slide out the SD and MicroSD holders.
    • If you are having trouble sliding them out, use the plastic opening tool.
  3. Dell Vostro V13 Keyboard Replacement: passo 3, imagem 1 %32 Dell Vostro V13 Keyboard Replacement: passo 3, imagem 2 %32 Dell Vostro V13 Keyboard Replacement: passo 3, imagem 3 %32
    • Slide the plastic opening tool around the perimeter of the laptop until the cover pops off.
    • Pull the back cover off.
  4. Dell Vostro V13 Keyboard Replacement: passo 4, imagem 1 %32 Dell Vostro V13 Keyboard Replacement: passo 4, imagem 2 %32
    • Remove the three black 3.9 mm Phillips #1 screws holding the battery in place.
  5. Dell Vostro V13 Keyboard Replacement: passo 5, imagem 1 %32 Dell Vostro V13 Keyboard Replacement: passo 5, imagem 2 %32 Dell Vostro V13 Keyboard Replacement: passo 5, imagem 3 %32
    • Flip up the clip of the ribbon connector.
    • Pull the strip out to disconnect the battery.
  6. Dell Vostro V13 Keyboard Replacement: passo 6, imagem 1 %32 Dell Vostro V13 Keyboard Replacement: passo 6, imagem 2 %32
    • Remove the battery.
    • Removing the battery allows you to work safely.
  7. Dell Vostro V13 Keyboard Replacement, Keyboard: passo 7, imagem 1 %32
    • Open the laptop so the keyboard is visible.
  8. Dell Vostro V13 Keyboard Replacement: passo 8, imagem 1 %32 Dell Vostro V13 Keyboard Replacement: passo 8, imagem 2 %32 Dell Vostro V13 Keyboard Replacement: passo 8, imagem 3 %32
    • Wedge the plastic opening tool around the seam of the notification panel to pop it off.
  9. Dell Vostro V13 Keyboard Replacement: passo 9, imagem 1 %32 Dell Vostro V13 Keyboard Replacement: passo 9, imagem 2 %32 Dell Vostro V13 Keyboard Replacement: passo 9, imagem 3 %32
    • Disconnect the ribbon connector on the panel.
    • Remove the panel.
  10. Dell Vostro V13 Keyboard Replacement: passo 10, imagem 1 %32 Dell Vostro V13 Keyboard Replacement: passo 10, imagem 2 %32
    • Remove the two silver 3.1 mm Phillips #1 screws.
  11. Dell Vostro V13 Keyboard Replacement: passo 11, imagem 1 %32 Dell Vostro V13 Keyboard Replacement: passo 11, imagem 2 %32
    • Use the plastic opening tool to pry the keyboard out of the laptop.
    • Do not pull the keyboard all the way out yet.
  12. Dell Vostro V13 Keyboard Replacement: passo 12, imagem 1 %32 Dell Vostro V13 Keyboard Replacement: passo 12, imagem 2 %32
    • Disconnect the ribbon cable that connects the keyboard to the laptop by flipping up the white locking tab on the ZIF connector.
    • If you're having trouble, use the plastic opening tool to help.
  13. Dell Vostro V13 Keyboard Replacement: passo 13, imagem 1 %32 Dell Vostro V13 Keyboard Replacement: passo 13, imagem 2 %32 Dell Vostro V13 Keyboard Replacement: passo 13, imagem 3 %32
    • Remove the keyboard.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 10
Duração total: 360
