Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
In this guide, we will be showing you how to remove the Solid-State Drive.
O que você precisa
Turn the computer over.
Slide the battery-bay release latch and the battery-lock latch towards the outer edges.
Slide the battery out of the battery bay.
Turn the computer top-side up, open the display, and press the power button to ground the system board.
Lift the cover off the computer at an angle as shown in the figure.
Remove the two screws that secure the solid-state drive.
Lift the solid-state drive out of its system board connector.
Uma outra pessoa concluiu este guia.
Um comentário
Remember the add the Warning steps that are found in the Service Manuals at the beginning of the guides.
