Ir para o conteúdo principal
Dell Vostro A90 Solid-State Drive Removal
O que você precisa
  1. Dell Vostro A90 Solid-State Drive Removal, Removing the Battery: passo 1, imagem 1 %32
    • Turn the computer over.
    • Slide the battery-bay release latch and the battery-lock latch towards the outer edges.
    • Slide the battery out of the battery bay.
    • Turn the computer top-side up, open the display, and press the power button to ground the system board.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  2. Dell Vostro A90 Solid-State Drive Removal, Remove the Screws: passo 2, imagem 1 %32
    • Remove the two screws on the module cover.
  3. Dell Vostro A90 Solid-State Drive Removal, Lifting the Cover: passo 3, imagem 1 %32
    • Lift the cover off the computer at an angle as shown in the figure.
  4. Dell Vostro A90 Solid-State Drive Removal, Remove Solid-State Drive: passo 4, imagem 1 %32
    • Remove the two screws that secure the solid-state drive.
    • Lift the solid-state drive out of its system board connector.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Johnathan Hammond
Membro desde: 02/28/18
44.830 Reputação
Autoria de 408 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
Um comentário
Remember the add the Warning steps that are found in the Service Manuals at the beginning of the guides.
Terrence15 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 172
