Ir para o conteúdo principal
Dell Vostro A860 RAM Memory Sticks Replacement
O que você precisa
  1. Dell Vostro A860 RAM Memory Sticks Replacement, RAM: passo 1, imagem 1 %32 Dell Vostro A860 RAM Memory Sticks Replacement, RAM: passo 1, imagem 2 %32
    • With the computer facing down locate the RAM compartment cover.
    • Unscrew the two screws holding the cover to the laptop chassis.
    • The screws do not remove completely, they are clipped into the compartment cover.
    • Lift up on the Memory cover and remove.
  2. Dell Vostro A860 RAM Memory Sticks Replacement: passo 2, imagem 1 %32
    • Using a plastic opening tool push outward on both sides of the RAM stick.
    • doing this will release the silver tension clips holding the memory sticks in place. Once released the stick will easily lift up and out of the unit.
Conclusão
Joshua Dennis
Membro desde: 03/25/16
528 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 1-5, Miles Spring 2016 Membro de UMass Dartmouth, Team 1-5, Miles Spring 2016
UMASSD-MILES-S16S1G5
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 13
Duração total: 421
