Pular para o conteúdo principal
Introdução
In this guide, we will be showing you how to remove and replace the Hard Drive.
Peças
Nenhum componente especificado.
  1. Unlock the battery by sliding the battery-lock latch towards the outer edge.
    • Unlock the battery by sliding the battery-lock latch towards the outer edge.
    • Slide the battery-bay release latch and hold it.
    • Remove the battery from the battery bay.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  2. Kits de reparo de android
    A new screen or battery is one kit away.
    Comprar agora
    Comprar agora
  3. Remove the two screws securing the hard drive assembly to the system board.
    • Remove the two screws securing the hard drive assembly to the system board.
    • Holding the connector end of the hard drive assembly, pull the hard drive assembly from the system board connector.
  4. Press down on the hard drive at the non-connector end slot to remove the hard drive off the hard drive cage.
    • Press down on the hard drive at the non-connector end slot to remove the hard drive off the hard drive cage.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Johnathan Hammond
Membro desde: 28-02-2018
36.179 reputação
408 Guias de autoria
Equipe
Informative Technologies Inc. Membro de Informative Technologies Inc.
Community
15 Membros
926 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 6
Todo: 141
