Ir para o conteúdo principal
Dell Vostro 5560 Battery Replacement
O que você precisa
  1. Dell Vostro 5560 Battery Replacement, Removing The Optical-Disk Drive: passo 1, imagem 1 %32
    • Remove the screw that secures the base cover to the computer.
    • Pull the optical-drive and remove from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  2. Dell Vostro 5560 Battery Replacement, Replacing the Base Cover: passo 2, imagem 1 %32 Dell Vostro 5560 Battery Replacement, Replacing the Base Cover: passo 2, imagem 2 %32
    • Remove the screws that secure the base cover to the computer.
    • Pry the base cover along the edges to loosen it. Lift and remove the base cover from the computer.
  3. Dell Vostro 5560 Battery Replacement, Removing the Battery: passo 3, imagem 1 %32
    • Disconnect the battery cable from its connector on the system board.
    • Lift and remove the battery from the computer.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Johnathan Hammond
Membro desde: 02/28/18
45.237 Reputação
Autoria de 408 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
43 Membros
Autoria de 1.985 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 333
